Switch relais output with sensor
Hello
I have a movement detector that switch 220V,
my idea is to connect the movement detector to my Velbus system, so that I can switch a relais output
How can i do this?
thx Sven
You could connect a 220V relay to the detector and use the relay contact to trigger the Velbus with either a pushbutton module or a 6-channel input module.
