Thermostat defaults
After a power loss the default thermostat mode is heat - would it be possible to change this to Cool?
Or should I use a virtual relay with a small timer to set all thermostats to cool after a power failure with a small timer ?
Or you could use one of the thermostat alarm channels to set the operating mode to cooling when the room is over a fixed temperature
that’s a good one… :slight_smile: … everything over 20C == Set to Cool mode …
