Troubles with dimmer module
Yesterday evening suddenly the light in my living room goes out!
1 dimmermodule doesn’t work anymore.
When I push the testbutton on the module the lights don’t work AND there is no communication (RX, TX don’t work)
When I push at any other module on the test button, the light RX on the dimmermodule is flashing, so the bus communication must be OK
What’s the problem here?
With velbuslink I can see the module (the module is still on the bus)
gr sven
If the module is defective (try first with a power down, and complete reboot of the modules), the module could be defective in the high voltage part.
Ronse ? -> You can always return the module for a quick checkup and/or repair.
A power reboot doesn’t help
Can i come with the module to the office in Gavere?
I send you an email…
Hello
I have the same problem with 2 of my dimmers. Can I send them in for a check?
You can return your items to your Velleman distributor or to:
Velleman Projects Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
