Hello
i try to make VMB7IN virtual channel to work , because i want to trigger 2 different outputs with one VMB7IN where one of the outputs is restricted to time range.
So i connect one output to ch6 another to CH8 and i disable CH8 in the program for the required time range.
Then i want CH6 trigger CH8 (virtual) each time its triggered by the IR detector.
Here where the problem appear as i told CH8 to follow the state of CH6 but it does not work.
Here an capture to explain it better .
Alot of thanks for the support team for quick answers.
I Found a hack to make it work , i activated DOUBLE mode on CH6 making him trigger CH8 after 1sec simulating long pression .
This is a dirty hack since it would be nice the “follow state” works or DOUBLE mode support 0sec delay .
Is there a “clean” way to do it ?
________ UPDATE___
for some reason in DOUBLE Mode CH6 is not working any more …
Is there anybody who can help ?
Regards
