Hi found a problem with release 6.0.10.1135
If I try to set a timer on VMB4PD all settings (timer mode off, ch4, ch8, enabled timer and time) assume a strange value.
I can set the first time, but if I exit from setting and open setting again the value are completely mistake.
Got some issues to, com-ports don’t get listed when connecting (you can however type your comport eg:“com1” in the dropdownlist).
VMB1TC trows the same error as the VMB1TS modules in the past, “Could not find memory definition file… bla bla XML” tried to find an XML from another firmware revision but I don’t have an VMB1TC_xxxx.xml in the Maps folder.
BTW: using version 6.0.10.1135 on Win7 x64
Regards,
Tim
