Hi ,
I’ve installed domogik and got the plugin installed,
but when I send a command it says in the log that the device is not known at address 2.
I have a relay at address 02 and want to switch on the lights at 02-2 , but I get this error.
Also when I start the plugin , just 3 modules are recognised.
here is a output log,
the strange thing is that when i push the buttons the bus is captured.
can you help me?
2013-09-04 22:25:46,874 domogik-velbus INFO write packet
2013-09-04 22:25:46,876 domogik-velbus INFO write packet
2013-09-04 22:25:46,877 domogik-velbus INFO Bus scan finished
2013-09-04 22:25:46,899 domogik-velbus INFO Start listening VELBUS
2013-09-04 22:25:46,901 domogik-velbus INFO Found node with address 0 and module_type VMB4PD
2013-09-04 22:25:46,910 domogik-velbus INFO Found node with address 7 and module_type VMB2PBN
2013-09-04 22:26:01,936 domogik-velbus INFO Found node with address 254 and module_type VMB6IN
2013-09-04 22:26:46,110 domogik-velbus ERROR Request to set a level on a device, but the device is not known. address 2
2013-09-04 22:26:46,308 domogik-velbus ERROR Request to set a level on a device, but the device is not known. address 2
2013-09-04 22:26:47,260 domogik-velbus ERROR Request to set a level on a device, but the device is not known. address 2
2013-09-04 22:28:05,672 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘6-1’, ‘current’: ‘HIGH’, ‘type’: ‘input’}
2013-09-04 22:28:05,694 domogik-velbus INFO schema:lighting.device, data:{‘device’: ‘2-2’, ‘level’: 100}
2013-09-04 22:28:05,708 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘2-2’, ‘current’: ‘HIGH’, ‘type’: ‘input’}
2013-09-04 22:28:05,831 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘6-1’, ‘current’: ‘LOW’, ‘type’: ‘input’}
2013-09-04 22:28:06,000 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘6-2’, ‘current’: ‘HIGH’, ‘type’: ‘input’}
2013-09-04 22:28:06,055 domogik-velbus INFO schema:lighting.device, data:{‘device’: ‘3-1’, ‘level’: 100}
2013-09-04 22:28:06,068 domogik-velbus INFO schema:lighting.device, data:{‘device’: ‘3-2’, ‘level’: 100}
2013-09-04 22:28:06,085 domogik-velbus INFO schema:lighting.device, data:{‘device’: ‘3-3’, ‘level’: 100}
2013-09-04 22:28:06,159 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘6-2’, ‘current’: ‘LOW’, ‘type’: ‘input’}
2013-09-04 22:28:06,275 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘6-3’, ‘current’: ‘HIGH’, ‘type’: ‘input’}
2013-09-04 22:28:06,328 domogik-velbus INFO schema:lighting.device, data:{‘device’: ‘3-1’, ‘level’: 0}
2013-09-04 22:28:06,342 domogik-velbus INFO schema:lighting.device, data:{‘device’: ‘3-2’, ‘level’: 0}
2013-09-04 22:28:06,356 domogik-velbus INFO schema:lighting.device, data:{‘device’: ‘3-3’, ‘level’: 0}
2013-09-04 22:28:06,421 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘6-3’, ‘current’: ‘LOW’, ‘type’: ‘input’}
2013-09-04 22:28:08,750 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘5-1’, ‘current’: ‘HIGH’, ‘type’: ‘input’}
2013-09-04 22:28:08,773 domogik-velbus INFO schema:lighting.device, data:{‘device’: ‘2-3’, ‘level’: 100}
2013-09-04 22:28:08,785 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘2-3’, ‘current’: ‘HIGH’, ‘type’: ‘input’}
2013-09-04 22:28:08,972 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘5-1’, ‘current’: ‘LOW’, ‘type’: ‘input’}
2013-09-04 22:28:24,044 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘5-1’, ‘current’: ‘HIGH’, ‘type’: ‘input’}
2013-09-04 22:28:24,067 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘2-3’, ‘current’: ‘LOW’, ‘type’: ‘input’}
2013-09-04 22:28:24,164 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘5-1’, ‘current’: ‘LOW’, ‘type’: ‘input’}
2013-09-04 22:28:26,904 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘6-1’, ‘current’: ‘HIGH’, ‘type’: ‘input’}
2013-09-04 22:28:26,926 domogik-velbus INFO schema:lighting.device, data:{‘device’: ‘2-2’, ‘level’: 0}
2013-09-04 22:28:26,941 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘2-2’, ‘current’: ‘LOW’, ‘type’: ‘input’}
2013-09-04 22:28:27,038 domogik-velbus INFO schema:sensor.basic, data:{‘device’: ‘6-1’, ‘current’: ‘LOW’, ‘type’: ‘input’}
^C
