The problem is solved adding domogik user to dialout group.
sudo adduser domogik dialout
Thank you!
Best regards,
Hugo.
Thank you!
Best regards,
Hugo.
Hello again.
I was now trying to add devices, and for what I could find:
VMB4RYNO
Module address: 00
Relay: 1
Address in Velbus plugin: 00-1
Is this correct?
When I try to toggle the widget, I get the error message:
[quote]RINOR : ‘No data or timeout on getting command response’
(/rinor/api/command/velbus/00-1/)[/quote]
Looks like it’s detecting a device that it’s not recognized.
The device at address 49 (0x31) is a VMBLCDWB (LCD Push-Button Panel). In fact, this device has 4 addresses: 49, 50, 51, 52 (0x31, 0x32, 0x33, 0x34).
After that, I have a VBMB7IN at address 64 (0x40).
Is there a way to bypass the detection at some addresses?
Logfile:
[code]2013-09-17 15:13:25,015 domogik-velbus INFO Daemonize plugin velbus
2013-09-17 15:13:25,035 domogik-velbus INFO ----------------------------------
2013-09-17 15:13:25,040 domogik-velbus INFO Starting plugin ‘velbus’ (new manager instance)
2013-09-17 15:13:25,578 domogik-velbus INFO Try to open VELBUS: /dev/ttyACM0
2013-09-17 15:13:25,592 domogik-velbus INFO write deamon
2013-09-17 15:13:25,597 domogik-velbus INFO VELBUS opened
2013-09-17 15:13:25,600 domogik-velbus INFO Starting the bus scan
2013-09-17 15:13:25,602 domogik-velbus INFO write packet
2013-09-17 15:13:25,633 domogik-velbus INFO write packet
2013-09-17 15:13:25,636 domogik-velbus INFO write packet
2013-09-17 15:13:25,638 domogik-velbus INFO write packet
2013-09-17 15:13:25,640 domogik-velbus INFO write packet
2013-09-17 15:13:25,654 domogik-velbus INFO write packet
2013-09-17 15:13:25,657 domogik-velbus INFO write packet
2013-09-17 15:13:25,665 domogik-velbus INFO write packet
2013-09-17 15:13:25,669 domogik-velbus INFO write packet
2013-09-17 15:13:25,677 domogik-velbus INFO write packet
2013-09-17 15:13:25,679 domogik-velbus INFO write packet
2013-09-17 15:13:25,681 domogik-velbus INFO write packet
2013-09-17 15:13:25,694 domogik-velbus INFO write packet
2013-09-17 15:13:25,696 domogik-velbus INFO write packet
2013-09-17 15:13:25,699 domogik-velbus INFO write packet
2013-09-17 15:13:25,701 domogik-velbus INFO write packet
2013-09-17 15:13:25,710 domogik-velbus INFO write packet
2013-09-17 15:13:25,723 domogik-velbus INFO write packet
2013-09-17 15:13:25,727 domogik-velbus INFO write packet
2013-09-17 15:13:25,730 domogik-velbus INFO write packet
2013-09-17 15:13:25,732 domogik-velbus INFO write packet
2013-09-17 15:13:25,739 domogik-velbus INFO write packet
2013-09-17 15:13:25,741 domogik-velbus INFO write packet
2013-09-17 15:13:25,754 domogik-velbus INFO write packet
2013-09-17 15:13:25,756 domogik-velbus INFO write packet
2013-09-17 15:13:25,758 domogik-velbus INFO write packet
2013-09-17 15:13:25,761 domogik-velbus INFO write packet
2013-09-17 15:13:25,773 domogik-velbus INFO write packet
2013-09-17 15:13:25,776 domogik-velbus INFO write packet
2013-09-17 15:13:25,778 domogik-velbus INFO write packet
2013-09-17 15:13:25,780 domogik-velbus INFO write packet
2013-09-17 15:13:25,794 domogik-velbus INFO write packet
2013-09-17 15:13:25,797 domogik-velbus INFO write packet
2013-09-17 15:13:25,805 domogik-velbus INFO write packet
2013-09-17 15:13:25,811 domogik-velbus INFO write packet
2013-09-17 15:13:25,813 domogik-velbus INFO write packet
2013-09-17 15:13:25,816 domogik-velbus INFO write packet
2013-09-17 15:13:25,818 domogik-velbus INFO write packet
2013-09-17 15:13:25,835 domogik-velbus INFO write packet
2013-09-17 15:13:25,837 domogik-velbus INFO write packet
2013-09-17 15:13:25,839 domogik-velbus INFO write packet
2013-09-17 15:13:25,842 domogik-velbus INFO write packet
2013-09-17 15:13:25,851 domogik-velbus INFO write packet
2013-09-17 15:13:25,854 domogik-velbus INFO write packet
2013-09-17 15:13:25,864 domogik-velbus INFO write packet
2013-09-17 15:13:25,867 domogik-velbus INFO write packet
2013-09-17 15:13:25,874 domogik-velbus INFO write packet
2013-09-17 15:13:25,876 domogik-velbus INFO write packet
2013-09-17 15:13:25,879 domogik-velbus INFO write packet
2013-09-17 15:13:25,881 domogik-velbus INFO write packet
2013-09-17 15:13:25,898 domogik-velbus INFO write packet
2013-09-17 15:13:25,900 domogik-velbus INFO write packet
2013-09-17 15:13:25,913 domogik-velbus INFO write packet
2013-09-17 15:13:25,915 domogik-velbus INFO write packet
2013-09-17 15:13:25,934 domogik-velbus INFO write packet
2013-09-17 15:13:25,944 domogik-velbus INFO write packet
2013-09-17 15:13:25,946 domogik-velbus INFO write packet
2013-09-17 15:13:25,957 domogik-velbus INFO write packet
2013-09-17 15:13:25,959 domogik-velbus INFO write packet
2013-09-17 15:13:25,962 domogik-velbus INFO write packet
2013-09-17 15:13:25,986 domogik-velbus INFO write packet
2013-09-17 15:13:25,989 domogik-velbus INFO write packet
2013-09-17 15:13:25,995 domogik-velbus INFO write packet
2013-09-17 15:13:26,020 domogik-velbus INFO write packet
2013-09-17 15:13:26,023 domogik-velbus INFO write packet
2013-09-17 15:13:26,026 domogik-velbus INFO write packet
2013-09-17 15:13:26,028 domogik-velbus INFO write packet
2013-09-17 15:13:26,045 domogik-velbus INFO write packet
2013-09-17 15:13:26,056 domogik-velbus INFO write packet
2013-09-17 15:13:26,063 domogik-velbus INFO write packet
2013-09-17 15:13:26,066 domogik-velbus INFO write packet
2013-09-17 15:13:26,076 domogik-velbus INFO write packet
2013-09-17 15:13:26,078 domogik-velbus INFO write packet
2013-09-17 15:13:26,080 domogik-velbus INFO write packet
2013-09-17 15:13:26,103 domogik-velbus INFO write packet
2013-09-17 15:13:26,106 domogik-velbus INFO write packet
2013-09-17 15:13:26,108 domogik-velbus INFO write packet
2013-09-17 15:13:26,110 domogik-velbus INFO write packet
2013-09-17 15:13:26,133 domogik-velbus INFO write packet
2013-09-17 15:13:26,173 domogik-velbus INFO write packet
2013-09-17 15:13:26,175 domogik-velbus INFO write packet
2013-09-17 15:13:26,178 domogik-velbus INFO write packet
2013-09-17 15:13:26,180 domogik-velbus INFO write packet
2013-09-17 15:13:26,182 domogik-velbus INFO write packet
2013-09-17 15:13:26,214 domogik-velbus INFO write packet
2013-09-17 15:13:26,217 domogik-velbus INFO write packet
2013-09-17 15:13:26,219 domogik-velbus INFO write packet
2013-09-17 15:13:26,233 domogik-velbus INFO write packet
2013-09-17 15:13:26,235 domogik-velbus INFO write packet
2013-09-17 15:13:26,237 domogik-velbus INFO write packet
2013-09-17 15:13:26,263 domogik-velbus INFO write packet
2013-09-17 15:13:26,267 domogik-velbus INFO write packet
2013-09-17 15:13:26,270 domogik-velbus INFO write packet
2013-09-17 15:13:26,293 domogik-velbus INFO write packet
2013-09-17 15:13:26,295 domogik-velbus INFO write packet
2013-09-17 15:13:26,298 domogik-velbus INFO write packet
2013-09-17 15:13:26,300 domogik-velbus INFO write packet
2013-09-17 15:13:26,323 domogik-velbus INFO write packet
2013-09-17 15:13:26,329 domogik-velbus INFO write packet
2013-09-17 15:13:26,332 domogik-velbus INFO write packet
2013-09-17 15:13:26,336 domogik-velbus INFO write packet
2013-09-17 15:13:26,346 domogik-velbus INFO write packet
2013-09-17 15:13:26,348 domogik-velbus INFO write packet
2013-09-17 15:13:26,350 domogik-velbus INFO write packet
2013-09-17 15:13:26,364 domogik-velbus INFO write packet
2013-09-17 15:13:26,367 domogik-velbus INFO write packet
2013-09-17 15:13:26,369 domogik-velbus INFO write packet
2013-09-17 15:13:26,371 domogik-velbus INFO write packet
2013-09-17 15:13:26,380 domogik-velbus INFO write packet
2013-09-17 15:13:26,390 domogik-velbus INFO write packet
2013-09-17 15:13:26,393 domogik-velbus INFO write packet
2013-09-17 15:13:26,404 domogik-velbus INFO write packet
2013-09-17 15:13:26,406 domogik-velbus INFO write packet
2013-09-17 15:13:26,409 domogik-velbus INFO write packet
2013-09-17 15:13:26,411 domogik-velbus INFO write packet
2013-09-17 15:13:26,424 domogik-velbus INFO write packet
2013-09-17 15:13:26,427 domogik-velbus INFO write packet
2013-09-17 15:13:26,429 domogik-velbus INFO write packet
2013-09-17 15:13:26,431 domogik-velbus INFO write packet
2013-09-17 15:13:26,441 domogik-velbus INFO write packet
2013-09-17 15:13:26,447 domogik-velbus INFO write packet
2013-09-17 15:13:26,450 domogik-velbus INFO write packet
2013-09-17 15:13:26,466 domogik-velbus INFO write packet
2013-09-17 15:13:26,469 domogik-velbus INFO write packet
2013-09-17 15:13:26,471 domogik-velbus INFO write packet
2013-09-17 15:13:26,474 domogik-velbus INFO write packet
2013-09-17 15:13:26,483 domogik-velbus INFO write packet
2013-09-17 15:13:26,485 domogik-velbus INFO write packet
2013-09-17 15:13:26,487 domogik-velbus INFO write packet
2013-09-17 15:13:26,490 domogik-velbus INFO write packet
2013-09-17 15:13:26,492 domogik-velbus INFO write packet
2013-09-17 15:13:26,508 domogik-velbus INFO write packet
2013-09-17 15:13:26,510 domogik-velbus INFO write packet
2013-09-17 15:13:26,523 domogik-velbus INFO write packet
2013-09-17 15:13:26,528 domogik-velbus INFO write packet
2013-09-17 15:13:26,544 domogik-velbus INFO write packet
2013-09-17 15:13:26,547 domogik-velbus INFO write packet
2013-09-17 15:13:26,549 domogik-velbus INFO write packet
2013-09-17 15:13:26,551 domogik-velbus INFO write packet
2013-09-17 15:13:26,554 domogik-velbus INFO write packet
2013-09-17 15:13:26,563 domogik-velbus INFO write packet
2013-09-17 15:13:26,565 domogik-velbus INFO write packet
2013-09-17 15:13:26,567 domogik-velbus INFO write packet
2013-09-17 15:13:26,570 domogik-velbus INFO write packet
2013-09-17 15:13:26,572 domogik-velbus INFO write packet
2013-09-17 15:13:26,581 domogik-velbus INFO write packet
2013-09-17 15:13:26,595 domogik-velbus INFO write packet
2013-09-17 15:13:26,598 domogik-velbus INFO write packet
2013-09-17 15:13:26,601 domogik-velbus INFO write packet
2013-09-17 15:13:26,607 domogik-velbus INFO write packet
2013-09-17 15:13:26,610 domogik-velbus INFO write packet
2013-09-17 15:13:26,612 domogik-velbus INFO write packet
2013-09-17 15:13:26,625 domogik-velbus INFO write packet
2013-09-17 15:13:26,627 domogik-velbus INFO write packet
2013-09-17 15:13:26,630 domogik-velbus INFO write packet
2013-09-17 15:13:26,632 domogik-velbus INFO write packet
2013-09-17 15:13:26,641 domogik-velbus INFO write packet
2013-09-17 15:13:26,644 domogik-velbus INFO write packet
2013-09-17 15:13:26,646 domogik-velbus INFO write packet
2013-09-17 15:13:26,664 domogik-velbus INFO write packet
2013-09-17 15:13:26,667 domogik-velbus INFO write packet
2013-09-17 15:13:26,670 domogik-velbus INFO write packet
2013-09-17 15:13:26,678 domogik-velbus INFO write packet
2013-09-17 15:13:26,680 domogik-velbus INFO write packet
2013-09-17 15:13:26,687 domogik-velbus INFO write packet
2013-09-17 15:13:26,689 domogik-velbus INFO write packet
2013-09-17 15:13:26,692 domogik-velbus INFO write packet
2013-09-17 15:13:26,705 domogik-velbus INFO write packet
2013-09-17 15:13:26,707 domogik-velbus INFO write packet
2013-09-17 15:13:26,709 domogik-velbus INFO write packet
2013-09-17 15:13:26,711 domogik-velbus INFO write packet
2013-09-17 15:13:26,726 domogik-velbus INFO write packet
2013-09-17 15:13:26,731 domogik-velbus INFO write packet
2013-09-17 15:13:26,733 domogik-velbus INFO write packet
2013-09-17 15:13:26,741 domogik-velbus INFO write packet
2013-09-17 15:13:26,748 domogik-velbus INFO write packet
2013-09-17 15:13:26,751 domogik-velbus INFO write packet
2013-09-17 15:13:26,763 domogik-velbus INFO write packet
2013-09-17 15:13:26,766 domogik-velbus INFO write packet
2013-09-17 15:13:26,768 domogik-velbus INFO write packet
2013-09-17 15:13:26,770 domogik-velbus INFO write packet
2013-09-17 15:13:26,779 domogik-velbus INFO write packet
2013-09-17 15:13:26,781 domogik-velbus INFO write packet
2013-09-17 15:13:26,794 domogik-velbus INFO write packet
2013-09-17 15:13:26,796 domogik-velbus INFO write packet
2013-09-17 15:13:26,798 domogik-velbus INFO write packet
2013-09-17 15:13:26,814 domogik-velbus INFO write packet
2013-09-17 15:13:26,816 domogik-velbus INFO write packet
2013-09-17 15:13:26,819 domogik-velbus INFO write packet
2013-09-17 15:13:26,821 domogik-velbus INFO write packet
2013-09-17 15:13:26,824 domogik-velbus INFO write packet
2013-09-17 15:13:26,826 domogik-velbus INFO write packet
2013-09-17 15:13:26,838 domogik-velbus INFO write packet
2013-09-17 15:13:26,841 domogik-velbus INFO write packet
2013-09-17 15:13:26,851 domogik-velbus INFO write packet
2013-09-17 15:13:26,863 domogik-velbus INFO write packet
2013-09-17 15:13:26,865 domogik-velbus INFO write packet
2013-09-17 15:13:26,868 domogik-velbus INFO write packet
2013-09-17 15:13:26,870 domogik-velbus INFO write packet
2013-09-17 15:13:26,877 domogik-velbus INFO write packet
2013-09-17 15:13:26,883 domogik-velbus INFO write packet
2013-09-17 15:13:26,885 domogik-velbus INFO write packet
2013-09-17 15:13:26,888 domogik-velbus INFO write packet
2013-09-17 15:13:26,890 domogik-velbus INFO write packet
2013-09-17 15:13:26,902 domogik-velbus INFO write packet
2013-09-17 15:13:26,905 domogik-velbus INFO write packet
2013-09-17 15:13:26,907 domogik-velbus INFO write packet
2013-09-17 15:13:26,909 domogik-velbus INFO write packet
2013-09-17 15:13:26,938 domogik-velbus INFO write packet
2013-09-17 15:13:26,952 domogik-velbus INFO write packet
2013-09-17 15:13:26,981 domogik-velbus INFO write packet
2013-09-17 15:13:26,996 domogik-velbus INFO write packet
2013-09-17 15:13:27,001 domogik-velbus INFO write packet
2013-09-17 15:13:27,009 domogik-velbus INFO write packet
2013-09-17 15:13:27,011 domogik-velbus INFO write packet
2013-09-17 15:13:27,018 domogik-velbus INFO write packet
2013-09-17 15:13:27,020 domogik-velbus INFO write packet
2013-09-17 15:13:27,028 domogik-velbus INFO write packet
2013-09-17 15:13:27,031 domogik-velbus INFO write packet
2013-09-17 15:13:27,043 domogik-velbus INFO write packet
2013-09-17 15:13:27,046 domogik-velbus INFO write packet
2013-09-17 15:13:27,048 domogik-velbus INFO write packet
2013-09-17 15:13:27,052 domogik-velbus INFO write packet
2013-09-17 15:13:27,066 domogik-velbus INFO write packet
2013-09-17 15:13:27,069 domogik-velbus INFO write packet
2013-09-17 15:13:27,071 domogik-velbus INFO write packet
2013-09-17 15:13:27,077 domogik-velbus INFO write packet
2013-09-17 15:13:27,085 domogik-velbus INFO write packet
2013-09-17 15:13:27,087 domogik-velbus INFO write packet
2013-09-17 15:13:27,090 domogik-velbus INFO write packet
2013-09-17 15:13:27,092 domogik-velbus INFO write packet
2013-09-17 15:13:27,104 domogik-velbus INFO write packet
2013-09-17 15:13:27,106 domogik-velbus INFO write packet
2013-09-17 15:13:27,115 domogik-velbus INFO write packet
2013-09-17 15:13:27,117 domogik-velbus INFO write packet
2013-09-17 15:13:27,119 domogik-velbus INFO write packet
2013-09-17 15:13:27,121 domogik-velbus INFO write packet
2013-09-17 15:13:27,146 domogik-velbus INFO write packet
2013-09-17 15:13:27,149 domogik-velbus INFO write packet
2013-09-17 15:13:27,151 domogik-velbus INFO write packet
2013-09-17 15:13:27,154 domogik-velbus INFO write packet
2013-09-17 15:13:27,156 domogik-velbus INFO write packet
2013-09-17 15:13:27,164 domogik-velbus INFO write packet
2013-09-17 15:13:27,166 domogik-velbus INFO write packet
2013-09-17 15:13:27,168 domogik-velbus INFO write packet
2013-09-17 15:13:27,171 domogik-velbus INFO write packet
2013-09-17 15:13:27,193 domogik-velbus INFO write packet
2013-09-17 15:13:27,196 domogik-velbus INFO write packet
2013-09-17 15:13:27,198 domogik-velbus INFO write packet
2013-09-17 15:13:27,200 domogik-velbus INFO write packet
2013-09-17 15:13:27,202 domogik-velbus INFO write packet
2013-09-17 15:13:27,222 domogik-velbus INFO write packet
2013-09-17 15:13:27,225 domogik-velbus INFO write packet
2013-09-17 15:13:27,228 domogik-velbus INFO write packet
2013-09-17 15:13:27,230 domogik-velbus INFO write packet
2013-09-17 15:13:27,233 domogik-velbus INFO Bus scan finished
2013-09-17 15:13:27,276 domogik-velbus INFO Start listening VELBUS
2013-09-17 15:13:27,280 domogik-velbus INFO Found node with address 0 and module_type VMB4RYNO
2013-09-17 15:13:27,799 domogik-velbus INFO Found node with address 32 and module_type VMB8PBU
2013-09-17 15:13:27,883 domogik-velbus INFO Found node with address 33 and module_type VMB8PBU
2013-09-17 15:13:27,952 domogik-velbus INFO Found node with address 34 and module_type VMB8PBU
2013-09-17 15:13:28,089 domogik-velbus INFO Found node with address 36 and module_type VMB8PBU
2013-09-17 15:13:28,159 domogik-velbus INFO Found node with address 37 and module_type VMB8PBU
2013-09-17 15:13:28,220 domogik-velbus INFO Found node with address 38 and module_type VMB8PBU
2013-09-17 15:13:28,288 domogik-velbus INFO Found node with address 39 and module_type VMB8PBU
2013-09-17 15:13:28,349 domogik-velbus INFO Found node with address 40 and module_type VMB8PBU
2013-09-17 15:13:28,962 domogik-velbus INFO Found node with address 49 and module_type VMBMPD
2013-09-17 15:13:28,983 domogik-velbus WARNING Received message with unknown type 176
2013-09-17 15:13:30,032 domogik-velbus ERROR Error while reading velbus device (disconnected ?) : Traceback (most recent call last):
File “/var/lib/domogik/domogik_packages/xpl/lib/velbus.py”, line 316, in listen
self.read()
File “/var/lib/domogik/domogik_packages/xpl/lib/velbus.py”, line 333, in read
self._parser(data[0:6+size])
File “/var/lib/domogik/domogik_packages/xpl/lib/velbus.py”, line 402, in _parser
methodcall( data )
File “/var/lib/domogik/domogik_packages/xpl/lib/velbus.py”, line 424, in _process_255
self._log.info(“Found node with address {0} and module_type {1}”.format(str(naddress), MODULE_TYPES[ntype]‘id’]))
KeyError: 34
2013-09-17 15:20:49,028 domogik-velbus INFO write packet[/code]
Best regards,
Hugo.
2 problems:
1- the velbus plugin your using does not support vmb7in yet
2- addresses are in the form of -
meaning
00/1 becomes 0-1
ff/1 becomes 255-1
[quote=“cereal”]2 problems:
meaning
00/1 becomes 0-1
ff/1 becomes 255-1[/quote]
Ok, but in this case, the point 2 doesn’t apply since the device has the address 00, so it’s the same. I also tried with just one “0” like 0-1.
Regarding the VMB7IN, can I bypass the detection of that module? It looks like that’s the error that interrupts the communication with the bus.
Best regards,
Hugo.
yes,
in the file domogik_packages/xpl/lib/velbus.py
add a new module to the list of module types:
with type 179
[quote=“cereal”]yes,
with type 179[/quote]
Hi!
I’ve just added a new module to the list, but the errors in the log file are the same.
EDIT: The warning line regarding the module 176 no longer appears, but the other error are there.
2013-09-18 13:34:52,806 domogik-velbus INFO Bus scan finished
2013-09-18 13:34:52,844 domogik-velbus INFO Start listening VELBUS
2013-09-18 13:34:52,877 domogik-velbus INFO Found node with address 0 and module_type VMB4RYNO
2013-09-18 13:34:53,584 domogik-velbus INFO Found node with address 32 and module_type VMB8PBU
2013-09-18 13:34:53,649 domogik-velbus INFO Found node with address 33 and module_type VMB8PBU
2013-09-18 13:34:53,715 domogik-velbus INFO Found node with address 34 and module_type VMB8PBU
2013-09-18 13:34:53,848 domogik-velbus INFO Found node with address 36 and module_type VMB8PBU
2013-09-18 13:34:53,899 domogik-velbus INFO Found node with address 37 and module_type VMB8PBU
2013-09-18 13:34:53,968 domogik-velbus INFO Found node with address 38 and module_type VMB8PBU
2013-09-18 13:34:54,022 domogik-velbus INFO Found node with address 39 and module_type VMB8PBU
2013-09-18 13:34:54,084 domogik-velbus INFO Found node with address 40 and module_type VMB8PBU
2013-09-18 13:34:54,706 domogik-velbus INFO Found node with address 49 and module_type VMBMPD
2013-09-18 13:34:55,726 domogik-velbus ERROR Error while reading velbus device (disconnected ?) : Traceback (most recent call last):
File "/var/lib/domogik/domogik_packages/xpl/lib/velbus.py", line 317, in listen
self.read()
File "/var/lib/domogik/domogik_packages/xpl/lib/velbus.py", line 334, in read
File "/var/lib/domogik/domogik_packages/xpl/lib/velbus.py", line 403, in _parser
methodcall( data )
File "/var/lib/domogik/domogik_packages/xpl/lib/velbus.py", line 425, in _process_255
self._log.info("Found node with address {0} and module_type {1}".format(str(naddress), MODULE_TYPES[ntype]'id']))
KeyError: 34
Best regards,
Hugo.
34 : {"id": "VMB7IN", "subtype": "INPUT"},
This should also be added to the MODULE_TYPES dict
the error below says its not in that list
[quote=“cereal”]
the error below says its not in that list[/quote]
You’re right. I’ve added the
176: {"id": "VMBLCDWB", "subtype": "INPUT"},
but not the 34.
Thanks.
Hello again.
Now I can control Velbus from Domoweb. But I still have another problem, and I didn’t wrote about it because I wanted to confirm with VelbusLink.
As you can see in the log file, the first module detected is at address 0, and the second module at address 32. But in fact I have 9 modules VMB4RYNO from 0-8 and 5 modules VMB2BLE from 16-20. I’ve just checked with VelbusLink and it can detect them, and they are working correctly.
BTW, I’m running Domogik and Domoweb in a Raspberry PI, and I can notice that it isn’t very fast loading the pages in Domoweb. Would it be more efficient having Domogik and Domoweb in different RPIs?
Thanks in advance for all your help.
Best regards,
Hugo.
yeah i know,
thats a bug in that version of the plugin.
in the latest version its fixed, but that version is only compatible with domogik 0.4.
i’ll check today what you need to change in you version.
Maikel
current plugin has the folowing code in bin/velbus.py
try:
self.manager.open(device, device_type)
except VelbusException as ex:
self.log.error(ex.value)
self.force_leave()
return
self.manager.scan()
listenthread = threading.Thread(None,
self.manager.listen,
"velbus-process-reader",
(self.get_stop(),),
self.register_thread(listenthread)
listenthread.start()
self.enable_hbeat()
the self.manager.scan should be moved down, that’s the problem your seeing
try:
self.force_leave()
return
self.manager.scan()
(self.get_stop(),),
self.manager.scan()
self.enable_hbeat()
The bug is that we start sending the scan messages before we start the thread that listens/receives messages on the bus.
i’ll update the repo plugin one of the next days, i’ll include vmb7in and this fix.
fixes are pushed,
at least tomorrow morning they should be visible on repo.domogik
Maikel
[quote=“cereal”]fixes are pushed,
Maikel[/quote]
Thank you, Maikel.
I’ll let you know if it worked.
Best regards,
Hugo.
[quote=“cereal”]current plugin has the folowing code in bin/velbus.py
try:
self.force_leave()
return
self.manager.scan()
(self.get_stop(),),
self.enable_hbeat()
try:
self.force_leave()
return
self.manager.scan()
(self.get_stop(),),
self.manager.scan()
self.enable_hbeat()
i’ll update the repo plugin one of the next days, i’ll include vmb7in and this fix.[/quote]
I’ve updated the file /bin/velbus.py, and now the plugin detects all the modules, but I still can’t control them.
Meanwhile something went wrong updating the plugin and when I reboot, the plugin disappears from control panel. I’m going to uninstall Domogik 0.2 and install the 0.3 version.
BTW, you forgot to remove the self.manager.scan() line up in the code.
Best regards,
Hugo.
I’ve uninstalled the previous versions of Domogik and Domoweb and now I have Domogik 0.3 and Domoweb 0.3-beta2.
I made the modification in velbus.py files, since the new update isn’t available at the repository yet.
The log file have no errors now, all modules are correctly detected, but I still can’t control the modules from address 1-8, only the module at address 0.
2013-09-20 16:03:22,028 domogik-velbus INFO Daemonize plugin velbus
2013-09-20 16:03:22,040 domogik-velbus INFO ----------------------------------
2013-09-20 16:03:22,045 domogik-velbus INFO Starting plugin 'velbus' (new manager instance)
2013-09-20 16:03:22,076 domogik-velbus INFO HUB discovery > starting
2013-09-20 16:03:22,082 domogik-velbus INFO HUB discovery > looking for the hub. I hope there is one hub, Domogik won't work without the hub!
2013-09-20 16:03:22,145 domogik-velbus INFO HUB discovery > Received HBEAT echo, HUB detected
2013-09-20 16:03:22,199 domogik-velbus INFO HUB discovery > hub found, configuration in progress
2013-09-20 16:03:22,235 domogik-velbus INFO HUB discovery > hub found, configuration in progress
2013-09-20 16:03:22,652 domogik-velbus INFO Try to open VELBUS: /dev/ttyACM0
2013-09-20 16:03:22,655 domogik-velbus INFO write deamon
2013-09-20 16:03:22,660 domogik-velbus INFO VELBUS opened
2013-09-20 16:03:22,666 domogik-velbus INFO Starting the bus scan
2013-09-20 16:03:22,668 domogik-velbus INFO write packet
2013-09-20 16:03:22,677 domogik-velbus INFO Start listening VELBUS
2013-09-20 16:03:22,686 domogik-velbus INFO write packet
2013-09-20 16:03:22,688 domogik-velbus INFO write packet
2013-09-20 16:03:22,690 domogik-velbus INFO write packet
2013-09-20 16:03:22,693 domogik-velbus INFO write packet
2013-09-20 16:03:22,704 domogik-velbus INFO write packet
2013-09-20 16:03:22,711 domogik-velbus INFO write packet
2013-09-20 16:03:22,714 domogik-velbus INFO write packet
2013-09-20 16:03:22,722 domogik-velbus INFO write packet
2013-09-20 16:03:22,721 domogik-velbus INFO Found node with address 0 and module_type VMB4RYNO
2013-09-20 16:03:22,736 domogik-velbus INFO write packet
2013-09-20 16:03:22,739 domogik-velbus INFO write packet
2013-09-20 16:03:22,748 domogik-velbus INFO write packet
2013-09-20 16:03:22,750 domogik-velbus INFO write packet
2013-09-20 16:03:22,757 domogik-velbus INFO write packet
2013-09-20 16:03:22,759 domogik-velbus INFO write packet
2013-09-20 16:03:22,761 domogik-velbus INFO write packet
2013-09-20 16:03:22,764 domogik-velbus INFO write packet
2013-09-20 16:03:22,773 domogik-velbus INFO write packet
2013-09-20 16:03:22,778 domogik-velbus INFO write packet
2013-09-20 16:03:22,785 domogik-velbus INFO write packet
2013-09-20 16:03:22,788 domogik-velbus INFO write packet
2013-09-20 16:03:22,791 domogik-velbus INFO Found node with address 1 and module_type VMB4RYNO
2013-09-20 16:03:22,798 domogik-velbus INFO write packet
2013-09-20 16:03:22,800 domogik-velbus INFO write packet
2013-09-20 16:03:22,804 domogik-velbus INFO write packet
2013-09-20 16:03:22,817 domogik-velbus INFO write packet
2013-09-20 16:03:22,819 domogik-velbus INFO write packet
2013-09-20 16:03:22,827 domogik-velbus INFO write packet
2013-09-20 16:03:22,829 domogik-velbus INFO write packet
2013-09-20 16:03:22,831 domogik-velbus INFO write packet
2013-09-20 16:03:22,841 domogik-velbus INFO write packet
2013-09-20 16:03:22,848 domogik-velbus INFO write packet
2013-09-20 16:03:22,851 domogik-velbus INFO write packet
2013-09-20 16:03:22,853 domogik-velbus INFO Found node with address 2 and module_type VMB4RYNO
2013-09-20 16:03:22,867 domogik-velbus INFO write packet
2013-09-20 16:03:22,869 domogik-velbus INFO write packet
2013-09-20 16:03:22,876 domogik-velbus INFO write packet
2013-09-20 16:03:22,879 domogik-velbus INFO write packet
2013-09-20 16:03:22,881 domogik-velbus INFO write packet
2013-09-20 16:03:22,883 domogik-velbus INFO write packet
2013-09-20 16:03:22,886 domogik-velbus INFO write packet
2013-09-20 16:03:22,899 domogik-velbus INFO write packet
2013-09-20 16:03:22,901 domogik-velbus INFO write packet
2013-09-20 16:03:22,933 domogik-velbus INFO write packet
2013-09-20 16:03:22,916 domogik-velbus INFO Found node with address 3 and module_type VMB4RYNO
2013-09-20 16:03:22,940 domogik-velbus INFO write packet
2013-09-20 16:03:22,946 domogik-velbus INFO write packet
2013-09-20 16:03:22,954 domogik-velbus INFO write packet
2013-09-20 16:03:22,956 domogik-velbus INFO write packet
2013-09-20 16:03:22,965 domogik-velbus INFO write packet
2013-09-20 16:03:22,972 domogik-velbus INFO write packet
2013-09-20 16:03:22,978 domogik-velbus INFO Found node with address 4 and module_type VMB4RYNO
2013-09-20 16:03:22,975 domogik-velbus INFO write packet
2013-09-20 16:03:22,987 domogik-velbus INFO write packet
2013-09-20 16:03:22,990 domogik-velbus INFO write packet
2013-09-20 16:03:22,992 domogik-velbus INFO write packet
2013-09-20 16:03:22,994 domogik-velbus INFO write packet
2013-09-20 16:03:23,001 domogik-velbus INFO write packet
2013-09-20 16:03:23,010 domogik-velbus INFO write packet
2013-09-20 16:03:23,013 domogik-velbus INFO write packet
2013-09-20 16:03:23,015 domogik-velbus INFO write packet
2013-09-20 16:03:23,029 domogik-velbus INFO write packet
2013-09-20 16:03:23,031 domogik-velbus INFO write packet
2013-09-20 16:03:23,034 domogik-velbus INFO Found node with address 5 and module_type VMB4RYNO
2013-09-20 16:03:23,036 domogik-velbus INFO write packet
2013-09-20 16:03:23,042 domogik-velbus INFO write packet
2013-09-20 16:03:23,044 domogik-velbus INFO write packet
2013-09-20 16:03:23,051 domogik-velbus INFO write packet
2013-09-20 16:03:23,061 domogik-velbus INFO write packet
2013-09-20 16:03:23,063 domogik-velbus INFO write packet
2013-09-20 16:03:23,066 domogik-velbus INFO write packet
2013-09-20 16:03:23,074 domogik-velbus INFO write packet
2013-09-20 16:03:23,077 domogik-velbus INFO write packet
2013-09-20 16:03:23,086 domogik-velbus INFO write packet
2013-09-20 16:03:23,089 domogik-velbus INFO write packet
2013-09-20 16:03:23,091 domogik-velbus INFO write packet
2013-09-20 16:03:23,093 domogik-velbus INFO write packet
2013-09-20 16:03:23,096 domogik-velbus INFO write packet
2013-09-20 16:03:23,109 domogik-velbus INFO write packet
2013-09-20 16:03:23,112 domogik-velbus INFO write packet
2013-09-20 16:03:23,114 domogik-velbus INFO write packet
2013-09-20 16:03:23,118 domogik-velbus INFO Found node with address 6 and module_type VMB4RYNO
2013-09-20 16:03:23,123 domogik-velbus INFO write packet
2013-09-20 16:03:23,129 domogik-velbus INFO write packet
2013-09-20 16:03:23,132 domogik-velbus INFO write packet
2013-09-20 16:03:23,141 domogik-velbus INFO write packet
2013-09-20 16:03:23,143 domogik-velbus INFO write packet
2013-09-20 16:03:23,151 domogik-velbus INFO write packet
2013-09-20 16:03:23,153 domogik-velbus INFO write packet
2013-09-20 16:03:23,162 domogik-velbus INFO write packet
2013-09-20 16:03:23,164 domogik-velbus INFO write packet
2013-09-20 16:03:23,174 domogik-velbus INFO write packet
2013-09-20 16:03:23,176 domogik-velbus INFO write packet
2013-09-20 16:03:23,178 domogik-velbus INFO write packet
2013-09-20 16:03:23,181 domogik-velbus INFO Found node with address 7 and module_type VMB4RYNO
2013-09-20 16:03:23,196 domogik-velbus INFO write packet
2013-09-20 16:03:23,199 domogik-velbus INFO write packet
2013-09-20 16:03:23,206 domogik-velbus INFO write packet
2013-09-20 16:03:23,208 domogik-velbus INFO write packet
2013-09-20 16:03:23,211 domogik-velbus INFO write packet
2013-09-20 16:03:23,218 domogik-velbus INFO write packet
2013-09-20 16:03:23,227 domogik-velbus INFO write packet
2013-09-20 16:03:23,235 domogik-velbus INFO Found node with address 8 and module_type VMB4RYNO
2013-09-20 16:03:23,239 domogik-velbus INFO write packet
2013-09-20 16:03:23,242 domogik-velbus INFO write packet
2013-09-20 16:03:23,244 domogik-velbus INFO write packet
2013-09-20 16:03:23,252 domogik-velbus INFO write packet
2013-09-20 16:03:23,261 domogik-velbus INFO write packet
2013-09-20 16:03:23,264 domogik-velbus INFO write packet
2013-09-20 16:03:23,274 domogik-velbus INFO write packet
2013-09-20 16:03:23,276 domogik-velbus INFO write packet
2013-09-20 16:03:23,278 domogik-velbus INFO write packet
2013-09-20 16:03:23,287 domogik-velbus INFO write packet
2013-09-20 16:03:23,289 domogik-velbus INFO write packet
2013-09-20 16:03:23,296 domogik-velbus INFO write packet
2013-09-20 16:03:23,302 domogik-velbus INFO write packet
2013-09-20 16:03:23,304 domogik-velbus INFO write packet
2013-09-20 16:03:23,313 domogik-velbus INFO write packet
2013-09-20 16:03:23,324 domogik-velbus INFO write packet
2013-09-20 16:03:23,326 domogik-velbus INFO write packet
2013-09-20 16:03:23,328 domogik-velbus INFO write packet
2013-09-20 16:03:23,336 domogik-velbus INFO write packet
2013-09-20 16:03:23,338 domogik-velbus INFO write packet
2013-09-20 16:03:23,340 domogik-velbus INFO write packet
2013-09-20 16:03:23,352 domogik-velbus INFO write packet
2013-09-20 16:03:23,361 domogik-velbus INFO write packet
2013-09-20 16:03:23,364 domogik-velbus INFO write packet
2013-09-20 16:03:23,367 domogik-velbus INFO write packet
2013-09-20 16:03:23,381 domogik-velbus INFO write packet
2013-09-20 16:03:23,383 domogik-velbus INFO write packet
2013-09-20 16:03:23,386 domogik-velbus INFO write packet
2013-09-20 16:03:23,388 domogik-velbus INFO write packet
2013-09-20 16:03:23,390 domogik-velbus INFO write packet
2013-09-20 16:03:23,393 domogik-velbus INFO write packet
2013-09-20 16:03:23,395 domogik-velbus INFO write packet
2013-09-20 16:03:23,405 domogik-velbus INFO write packet
2013-09-20 16:03:23,412 domogik-velbus INFO write packet
2013-09-20 16:03:23,416 domogik-velbus INFO write packet
2013-09-20 16:03:23,423 domogik-velbus INFO write packet
2013-09-20 16:03:23,426 domogik-velbus INFO write packet
2013-09-20 16:03:23,429 domogik-velbus INFO write packet
2013-09-20 16:03:23,437 domogik-velbus INFO write packet
2013-09-20 16:03:23,439 domogik-velbus INFO write packet
2013-09-20 16:03:23,441 domogik-velbus INFO write packet
2013-09-20 16:03:23,452 domogik-velbus INFO write packet
2013-09-20 16:03:23,463 domogik-velbus INFO write packet
2013-09-20 16:03:23,465 domogik-velbus INFO write packet
2013-09-20 16:03:23,468 domogik-velbus INFO write packet
2013-09-20 16:03:23,477 domogik-velbus INFO write packet
2013-09-20 16:03:23,484 domogik-velbus INFO write packet
2013-09-20 16:03:23,487 domogik-velbus INFO write packet
2013-09-20 16:03:23,489 domogik-velbus INFO write packet
2013-09-20 16:03:23,491 domogik-velbus INFO write packet
2013-09-20 16:03:23,500 domogik-velbus INFO write packet
2013-09-20 16:03:23,502 domogik-velbus INFO write packet
2013-09-20 16:03:23,510 domogik-velbus INFO write packet
2013-09-20 16:03:23,521 domogik-velbus INFO write packet
2013-09-20 16:03:23,524 domogik-velbus INFO write packet
2013-09-20 16:03:23,527 domogik-velbus INFO write packet
2013-09-20 16:03:23,529 domogik-velbus INFO write packet
2013-09-20 16:03:23,531 domogik-velbus INFO write packet
2013-09-20 16:03:23,542 domogik-velbus INFO write packet
2013-09-20 16:03:23,545 domogik-velbus INFO write packet
2013-09-20 16:03:23,556 domogik-velbus INFO write packet
2013-09-20 16:03:23,559 domogik-velbus INFO write packet
2013-09-20 16:03:23,562 domogik-velbus INFO write packet
2013-09-20 16:03:23,567 domogik-velbus INFO write packet
2013-09-20 16:03:23,569 domogik-velbus INFO write packet
2013-09-20 16:03:23,583 domogik-velbus INFO write packet
2013-09-20 16:03:23,586 domogik-velbus INFO write packet
2013-09-20 16:03:23,588 domogik-velbus INFO write packet
2013-09-20 16:03:23,591 domogik-velbus INFO write packet
2013-09-20 16:03:23,593 domogik-velbus INFO write packet
2013-09-20 16:03:23,595 domogik-velbus INFO write packet
2013-09-20 16:03:23,604 domogik-velbus INFO write packet
2013-09-20 16:03:23,611 domogik-velbus INFO write packet
2013-09-20 16:03:23,618 domogik-velbus INFO write packet
2013-09-20 16:03:23,621 domogik-velbus INFO write packet
2013-09-20 16:03:23,627 domogik-velbus INFO write packet
2013-09-20 16:03:23,629 domogik-velbus INFO write packet
2013-09-20 16:03:23,632 domogik-velbus INFO write packet
2013-09-20 16:03:23,646 domogik-velbus INFO write packet
2013-09-20 16:03:23,648 domogik-velbus INFO write packet
2013-09-20 16:03:23,658 domogik-velbus INFO write packet
2013-09-20 16:03:23,660 domogik-velbus INFO write packet
2013-09-20 16:03:23,668 domogik-velbus INFO write packet
2013-09-20 16:03:23,677 domogik-velbus INFO write packet
2013-09-20 16:03:23,679 domogik-velbus INFO write packet
2013-09-20 16:03:23,681 domogik-velbus INFO write packet
2013-09-20 16:03:23,687 domogik-velbus INFO write packet
2013-09-20 16:03:23,690 domogik-velbus INFO write packet
2013-09-20 16:03:23,692 domogik-velbus INFO write packet
2013-09-20 16:03:23,694 domogik-velbus INFO write packet
2013-09-20 16:03:23,707 domogik-velbus INFO write packet
2013-09-20 16:03:23,710 domogik-velbus INFO write packet
2013-09-20 16:03:23,712 domogik-velbus INFO write packet
2013-09-20 16:03:23,723 domogik-velbus INFO write packet
2013-09-20 16:03:23,729 domogik-velbus INFO write packet
2013-09-20 16:03:23,736 domogik-velbus INFO write packet
2013-09-20 16:03:23,739 domogik-velbus INFO write packet
2013-09-20 16:03:23,742 domogik-velbus INFO Found node with address 16 and module_type VMB2BLE
2013-09-20 16:03:23,745 domogik-velbus INFO write packet
2013-09-20 16:03:23,754 domogik-velbus INFO write packet
2013-09-20 16:03:23,762 domogik-velbus INFO write packet
2013-09-20 16:03:23,767 domogik-velbus INFO write packet
2013-09-20 16:03:23,769 domogik-velbus INFO write packet
2013-09-20 16:03:23,771 domogik-velbus INFO write packet
2013-09-20 16:03:23,785 domogik-velbus INFO write packet
2013-09-20 16:03:23,787 domogik-velbus INFO write packet
2013-09-20 16:03:23,798 domogik-velbus INFO write packet
2013-09-20 16:03:23,804 domogik-velbus INFO Found node with address 17 and module_type VMB2BLE
2013-09-20 16:03:23,801 domogik-velbus INFO write packet
2013-09-20 16:03:23,809 domogik-velbus INFO write packet
2013-09-20 16:03:23,811 domogik-velbus INFO write packet
2013-09-20 16:03:23,825 domogik-velbus INFO write packet
2013-09-20 16:03:23,828 domogik-velbus INFO write packet
2013-09-20 16:03:23,836 domogik-velbus INFO write packet
2013-09-20 16:03:23,838 domogik-velbus INFO write packet
2013-09-20 16:03:23,840 domogik-velbus INFO write packet
2013-09-20 16:03:23,842 domogik-velbus INFO write packet
2013-09-20 16:03:23,851 domogik-velbus INFO write packet
2013-09-20 16:03:23,858 domogik-velbus INFO write packet
2013-09-20 16:03:23,865 domogik-velbus INFO write packet
2013-09-20 16:03:23,867 domogik-velbus INFO write packet
2013-09-20 16:03:23,871 domogik-velbus INFO Found node with address 18 and module_type VMB2BLE
2013-09-20 16:03:23,877 domogik-velbus INFO write packet
2013-09-20 16:03:23,879 domogik-velbus INFO write packet
2013-09-20 16:03:23,882 domogik-velbus INFO write packet
2013-09-20 16:03:23,896 domogik-velbus INFO write packet
2013-09-20 16:03:23,898 domogik-velbus INFO write packet
2013-09-20 16:03:23,906 domogik-velbus INFO write packet
2013-09-20 16:03:23,908 domogik-velbus INFO write packet
2013-09-20 16:03:23,912 domogik-velbus INFO write packet
2013-09-20 16:03:23,926 domogik-velbus INFO write packet
2013-09-20 16:03:23,931 domogik-velbus INFO write packet
2013-09-20 16:03:23,929 domogik-velbus INFO Found node with address 19 and module_type VMB2BLE
2013-09-20 16:03:23,933 domogik-velbus INFO write packet
2013-09-20 16:03:23,947 domogik-velbus INFO write packet
2013-09-20 16:03:23,949 domogik-velbus INFO write packet
2013-09-20 16:03:23,956 domogik-velbus INFO write packet
2013-09-20 16:03:23,961 domogik-velbus INFO write packet
2013-09-20 16:03:23,964 domogik-velbus INFO write packet
2013-09-20 16:03:23,978 domogik-velbus INFO write packet
2013-09-20 16:03:23,982 domogik-velbus INFO write packet
2013-09-20 16:03:23,989 domogik-velbus INFO write packet
2013-09-20 16:03:23,992 domogik-velbus INFO write packet
2013-09-20 16:03:23,996 domogik-velbus INFO Found node with address 20 and module_type VMB2BLE
2013-09-20 16:03:23,994 domogik-velbus INFO write packet
2013-09-20 16:03:24,004 domogik-velbus INFO write packet
2013-09-20 16:03:24,009 domogik-velbus INFO write packet
2013-09-20 16:03:24,013 domogik-velbus INFO write packet
2013-09-20 16:03:24,024 domogik-velbus INFO write packet
2013-09-20 16:03:24,027 domogik-velbus INFO write packet
2013-09-20 16:03:24,029 domogik-velbus INFO write packet
2013-09-20 16:03:24,032 domogik-velbus INFO write packet
2013-09-20 16:03:24,034 domogik-velbus INFO write packet
2013-09-20 16:03:24,044 domogik-velbus INFO write packet
2013-09-20 16:03:24,053 domogik-velbus INFO write packet
2013-09-20 16:03:24,055 domogik-velbus INFO write packet
2013-09-20 16:03:24,058 domogik-velbus INFO write packet
2013-09-20 16:03:24,067 domogik-velbus INFO write packet
2013-09-20 16:03:24,069 domogik-velbus INFO write packet
2013-09-20 16:03:24,079 domogik-velbus INFO write packet
2013-09-20 16:03:24,081 domogik-velbus INFO write packet
2013-09-20 16:03:24,083 domogik-velbus INFO write packet
2013-09-20 16:03:24,097 domogik-velbus INFO write packet
2013-09-20 16:03:24,101 domogik-velbus INFO write packet
2013-09-20 16:03:24,106 domogik-velbus INFO write packet
2013-09-20 16:03:24,116 domogik-velbus INFO Bus scan finished
2013-09-20 16:03:24,735 domogik-velbus INFO Found node with address 32 and module_type VMB8PBU
2013-09-20 16:03:24,797 domogik-velbus INFO Found node with address 33 and module_type VMB8PBU
2013-09-20 16:03:24,859 domogik-velbus INFO Found node with address 34 and module_type VMB8PBU
2013-09-20 16:03:24,984 domogik-velbus INFO Found node with address 36 and module_type VMB8PBU
2013-09-20 16:03:25,043 domogik-velbus INFO Found node with address 37 and module_type VMB8PBU
2013-09-20 16:03:25,106 domogik-velbus INFO Found node with address 38 and module_type VMB8PBU
2013-09-20 16:03:25,181 domogik-velbus INFO Found node with address 39 and module_type VMB8PBU
2013-09-20 16:03:25,260 domogik-velbus INFO Found node with address 40 and module_type VMB8PBU
2013-09-20 16:03:25,807 domogik-velbus INFO Found node with address 49 and module_type VMBMPD
2013-09-20 16:03:25,822 domogik-velbus WARNING Received message with unknown type 176
2013-09-20 16:03:26,728 domogik-velbus INFO Found node with address 64 and module_type VMB7IN
Best regards,
Hugo.
switch to log_level DEBUG in domogik.cfg, will give a lot more info
I installed Domogik 0.2.0 & Domoweb 0.2.1 on a virtual LinuxMint 15 (kernel 3.8.0) machine. The configuration works well but when installing the nigthy build plugin Velbus 0.5.0.dev20131013 I get following error in manager.log:
2013-10-13 14:20:47,918 domogik-manager ERROR Error while installing package 'cache:plugin/velbus/0.5.0.dev20131013' : Traceback (most recent call last):
File "/usr/local/lib/python2.7/dist-packages/Domogik-0.2.0_beta1-py2.7.egg/domogik/xpl/bin/manager.py", line 1368, in _pkg_install
status = self.pkg_mgr.install_package(package, package_part = package_part)
File "/usr/local/lib/python2.7/dist-packages/Domogik-0.2.0_beta1-py2.7.egg/domogik/common/packagemanager.py", line 430, in install_package
pkg_data.insert()
File "/usr/local/lib/python2.7/dist-packages/Domogik-0.2.0_beta1-py2.7.egg/domogik/common/packagedata.py", line 68, in insert
print("Technology %s" % self.pkg"technology"]"id"])
KeyError: 'technology'
Both database tables core_device_feature and core_device_technology stay empty.
(When starting velserv on /dev/ttyACM0 communication on the velbus is running faultless).
Has anyone an idea how to correct this problem?
With thanks.
there was a problem on repo.domogik, it was generating the nigthly packages from the wrong branch.
its fixed now and the nightly package will be fixed tomorrow morning
After long trial and error and reading the forum I managed to get Domogik 0.3 and Domoweb 0.3 running with the velbus plugin on a Raspberry Pi.
The only issue I have is that my VMB4DC is not recognized. Is this device supported?
i don’t have a vmb4dc, so i can not test it …
i will be happy to add support of needed
