When I add it to the devices as a dimmer in the visualization section it will not show the widget for a dimmer. It does show the visualization for a switch but when I press it it says Err - Rinor : No Data or timeout on getting command response (/rinor/api/command/velbus/16_1/)
the dmg_dump does recognize commands if I press the switches of the VMB4DC
hop=1
source+domogik.velbus.raspberrypi
target=*
lighting.device
device=16.1
level=0
Ill check previous posts on which logs you need and generate them and send them in a next post
Thanks for the quick reply cereal. I tried your solution and get the following.
root@domogik:~# pip install pyserial
The directory ‘/home/davy/.cache/pip/log’ or its parent directory is not owned by the current user and the debug log has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want the -H flag.
The directory ‘/home/davy/.cache/pip/http’ or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want the -H flag.
Requirement already satisfied (use --upgrade to upgrade): pyserial in /usr/local/lib/python2.7/dist-packages/pyserial-2.7-py2.7.egg
root@domogik:~# exit
exit
davy@domogik:~$ pip install pyserial
When I installed domogik & domoweb @ ESXi I just followed the documentation without any bump in the road. But when I installed it on a physical machine I had to install the following package manually before I could finalese the domogik install.
