The .net solution explain not really what I was hoping to understand.
I really need to know is these unused bit will be used for a later version of the protocol or if those bit will never be used and are fixed.
priority
If I understand correctly.
In the second byte (byte[1]), the priority byte, there are only 2bits in use.
High = 0xF8 --> in bits: 1111 1000
Low = 0xFB --> in bits: 1111 1011
Bitwise OR --------------
Difference 0000 0011
It’s seems that only those 2 bits are in use.
But then, if I look at your code in PacketParser.cs:line 113
packet.Priority = (m_Buffer[1] == 0xF8 ? PacketPriority.High : PacketPriority.Low);
This means that all packets are priority low exept for 0xF8.
shoutn’t it be:
if (m_Buffer[1] == 0xF8) // if the byte is exactly 0xF8
packet.Priority = PacketPriority.High
else if (m_Buffer[1] == 0xFB) // if the byte is exactly 0xFB
packet.Priority = PacketPriority.Low
else // all the rest
throw new PacketException(); // OR throw new NotSupportedException();
OR maybe even better.
if ((m_Buffer[1] & 0x03) == 0x03) // if the 2 bits are on
else if ((m_Buffer[1] & 0x03) == 0x00) // if the 2 bit are off
else // if only one of the 2 bits is on
In this solution, I don’t even look at the other bits.
Byte[3] Number of Data bytes + RTR bit
something the same as above.
if I look again in the code --> Packet.cs:Line167
the number of databyte (or datasize) can be from 0–>8.
This means 9 possibilities, the first 4 bits(bit[0,1,2,3]) for the number of Data Bytes + the 7th bit(bit[6]) for RTR.
So bit[4,5 and 7] are not in use.
I am really looking in bit lvl to really good understand the protocol.
Priority
There is no bit-level significance, 0xF8 is high priority, and 0xFB is low priority. This is a fixed value field of byte-width.
The parser already checked the validity of the priority byte in ValidHeaderWaiting(), so it is safe to assume that all bytes != 0xF8 are 0xFB.
Number of data bytes + Rtr
The maximum packet size is 14 bytes. There are 6 framing bytes, thus the number of data bytes is limited to 8 (14-6).
The rtr flag is set by flagging the most significant bit (0x40). Any other bits have no relevance, and will likely not be used in the future.
I hope this answers your questions
Have fun programming
Will there be a modules where you can communicate wireless.
Exemple:
A relay with wireless, so I don’t have to connect it to the bus by wire.
or
A wireless module to another wireless module. The 2 modules are connected to a wireless bus.
The modules communicate in a different way than you do via the VMB1RS interface. So i don’t think it’s possible to communicate directly to a module.
The only thing you can do is put up a server that’s connected to the velbus network. This server can then accept connections via tcp/ip, which of course can be established via a wireless network.
Maybe R&D will create a wireless alternative for the VMB1RY in the future… but it’s not all that easy. I can image they’ll need some kind of dhcp or whatever networking mojo to get an ip address and what about security, etc.
with all respect, try to find me a 486 that supports usb and the .NET framework (for your library)
However, since I’m interested myself in developing a 17" touchscreen application in .NET controlling the VelBus, I am interested too in some dedicated PC solution. This should be one supporting .NET, not consume too much and prefereably keep running when the power drops (ups-like). The cheapest solution seems to be an old laptop?
Another option would have been a PDA, since the VelBus framework is very easily ported to the Compact Framework, provided that the PDA has either USB host capability or a RS232 connection. However this option is set aside since this cannot be used with a large touchscreen.
