I actually use and try the windows 8 beta os. But I have a problem with the driver of the vmb1usb, it’s impossible to install it, there Is an error, so I can’t use velbuslink and I can’t update m’y Velbus installation.
Do you know this problem?
Do you have a solution?
Do you have a driver for windows 8, and/or an older/other driver that I coule try.
I can’t the actual driver on windows 7, mayby the file is corrupt, can you try it?
Tank you
