I have a Velbus installation in my 3year old house, and every year i have to manually connect my laptop to my setup and sync my clock because of it not automatically doing so during summer/winter time.
I do not find info anywhere on what is causing this, if i just need to enable an option or if my hardware/software is not able to do so.
i manly have VMB4RYLD, VMB4RYNO and one VMB2BLE
my software is up2date, i use ‘home automation’ (through my synology) to controle and check my house.
I am by no means an experienced user but with some help i manage my setup
Thanks in advance and i hope someone can help me out!
Ten years ago, when I first started with Velbus, I wondered about that too. Velbus even offered me one of those RTCs at reduced price. I never bothered and still don’t. I gather that setting the time twice a year on a GPOD is really easy and quick, it helps adjusting the clock that runs quite close to true time. And it is probably a lot less hassle and cost than trying to automate it. I need to do the tour of the house to reset clocks twice a year anyway. Velbus is just one more quick stop. What is the issue with that?
If I need another function and the time sync comes free, I will put it in. But on itself, I don’t find it enough of a downside to not have it to spend time and money on.
Thanks for the nice words. Some people may also call me lazy Truth is I’m 63 years of age and I have experienced that all this modern stuff is really nice but needs constant maintenance and can become a real drag. Simpler solutions tend to have less of that.
For instance: Synology recently pushed an update to my NAS and as a result, a few things I had built myself stopped working. So I had to spend time getting it to work again. I know, I should package it in a container. Even more work.
Then my robot mower (Robomow RL850, 2011) started acting up. It would no longer charge. Temporary fix: I charge the 12 V lead-acids with my specialized car charger (great thing, Optimate). Soon after one of the batteries died.
Then the central heating system started to loose pressure. Leaking automatic valves. I had to add so much fresh water now there is not enough inhibitor left in the system and I need to refill that, only I don’t know what the guy who first did it used so I can’t just refill, I need to completely drain and refill… it never ends!!
Besides of the beautiful glass panels, that’s one of the reasons I choose Velbus. It just works. The ‘nice to haves’ is still possible with HA, OpenHAB or the Velbus Gateway… But that server fails, I can still turn on the light.
