Velbuslink: Com port changes
Sometimes the com port number of the Velbus connection changes - especially when I pull out the usb plug and plug it in again.
Is this normal behaviour or is there an odd reason for this?
This is especially annoying when using the c# api where I have to specify a ‘hard-coded’ com port number.
Is there a workaround for this? How to find the right port nr using c#?
I connect my pc to Velbus using the usb module.
I’m using Vista Ultimate 32bit.
Thanks a lot,
Gert
This is normal Windows behaviour :slight_smile:
No workaround at this time
hm … there must be a way to automatically check com ports and find the velbus … I’ll look around and post if I find a solution …
I found a way to scan for the velbus usb com port and automatically connect to this port:
I added this snippet to the SerialBus class:
ManagementObjectSearcher searcher = new ManagementObjectSearcher("root\\WMI", "SELECT * FROM MSSerial_PortName"); foreach (ManagementObject queryObj in searcher.Get()) { //this will give back the pid and vid, which is unique for each device. //The Velbus gives back "VID_10CF&PID_0B1B", so check for this id: sInstanceName = queryObj"InstanceName"].ToString(); Debug.WriteLine(">>>" + sInstanceName); if (sInstanceName.IndexOf("VID_10CF&PID_0B1B") > -1) { portName = queryObj"PortName"].ToString(); Debug.WriteLine(">>>Velbus com port: " + portName); } }
Now you know the com port and could simply pass it to m_serialPort:
m_SerialPort = new SerialPort(portName, baudRate);
Warning: This only works if UAC is off or if you run as admin.
