Velbuslink error
http://snag.gy/bngpv.jpg
i get the above error always when i try to save my velbus configuration.
i already started a new project, and still the same
velbuslink version: 8.10.1.2006
any help?
What do you always configure that’s special?
nothing,
i just start a new project, and connect to my installation, i then scan for all modules.
once all modules have been found, i synchronize (read) all settings and try to save it.
Can you try to find out which module is causing the error? VelbusLink probably read a setting inside one of the modules that it did not expect.
i’ll try it tonight (when i’m at home)
but i ahve 32 modules installed so this will be a lot of work …
I would primarily suspect VMB4PD, VMBGPx and VMB1TC modules. I will also provide you with the latest version by this evening, maybe that will already solve this particular problem.
i have:
8 vmb4yrld
2 vmb4yrno
1 vmb6in
12 VMB6PBN
1 vmb1ts
1 vmb1dm
1 vmb1led
hmm, its seems its only 26 modules
ok i narrowed it down to one module:
VMB6PBN build 1135
now this module is the only one that has programs enabled, sunrise+sunset
anything else you need for info?
also i get the same error if i try to configure the module after i read it out
That was very helpful, this version should fix the error without any loss of data:
velbus.eu/downloads/velbusli … 0.2621.zip
Thank you for your help in troubleshooting this problem!
thanks,
this one indeed solves the problem
what else is new in this version?
It can also configure any VMBGP* module
just found something strange
when i read out all my vmb6pbn
the first char of the first channel is always wrong, it seems that its always 5 or @. Its only for the vmb6pbn, not for the other modules and only for the first channel name
