Velbuslink software bug?
When trying to enable the temperature indicator of my VMBGP4PIR I always get an addressing error: “The address has already been assigned to another module, Please choose another address- can not focus on a disabled or invisible window”.
I am sure that when I type in a non-existing address the error still occurs. The error also occurs when I let Velbuslink do the addressing.
This is a very anoying thing. Any help would be much appreciated!
Is it possible that you have a module with address = 00? Older versions of Velbuslink allowed this, in the latest versions we don’t allow this any more, it might be related.
(You do use the latest version of Velbuslink I suppose, 9.80.0.9, just checking…)
Dear VEL345,
Am a belgian user - using latest Velbuslink 9.80.0.9.
Checked the .VLP file and can not find any 00? address.
First address in my configuration is 00 and numbering up. I have one module where I manually gave addresses (this is the one I started with).
So addresses are not consecutively been used.
Can this be a part of the problem ?
The error happens on a VMBGP4PIR when I press F3 address management and select the tick box in front of thermostat. The software automatically gives an address, which I think is nowhere used, but when I click the button “write changes” I get the error.
In the .VLP file the module has the following entry:
Gang-Centraal-VMBGP4PIR
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
Hope you can help me ?
If wanted I can send you the .VLP file, but please explain me how to do that.
Thx a lot
Hi Vel345,
Think I solved it. One of the VMBGPOD had starting address 00.
Having changed that manually to something else, I could activate the thermostat on the PIRs.
Thx - topic can be closed
