is it correct that when using the velbuslink software, all rotating “MODE” switches are supposed to be on “0”?
If so, how do I select for example a staircase lighting timer in the software application?
If you do need to use the rotating “MODE” switches to select a specific program (like the staircase lighting timer), what mode do I select in the software application when adding a button to a relay module? “Activate modus”? “Troggle”?
Cheers,
Peter
