Is it possible to buy a ventilationsystem (C or D) from velleman/velbus, working on/with velbus?
Velbus only sells modules.
Using relay modules and 0-10V controllers, you will be able to control a wide range of ventilation systems.
Kris Daelman
What brand of heat recovery systems for family homes can directly conntected to a 1-10V Velbus controller?
I can only find Dutch ventilation systems with works with a “4 step switch”:
klusidee.nl/Forum/userpix/45 … nden_1.jpg
What you suppose to do with the other 3 channels of the 1-10V Velbus controller? You only need one channel for ventilation. But have to buy 4 channels.
The HRV unit brinkclimatesystems.nl/getattachment/d45edf13-0f1a-4a42-87e1-ea0b9234d909/612010-Renovent-Excellent—Rev-C.aspx with the “PLUS” extension has a 0-10V input. (by changing the default settings you can get a second 0-10Volt input)
I have this system and its connected to 0-10 velbus output.
It works great.
Regards
