I have a VMA430 to which I connect to an aircraft conspicuity system via the USB connection which also supplies power
Is it possible to also supply another instrument simultaneously via the UART connector without degradation of the data?
You might not get any info here - this forum is for Velbus stuff.
As @PrzemoF says, this is the Velbus forum for Velleman.
Is the VMA430 a Whadda product?
Try the Whadda forum
I’ve been playing around with this Serial GPS module from M5Stack
But as with all Serial devices, I wouldn’t consider splitting the output to multiple hosts.
You could use an Arduino to copy the data to multiple destinations?
But again, not really a Velbus solution ![]()
