Is there any particular reason for the blind modules to not be able to do 2, 6, 15, 19 seconds?
Maths.
And it’s highly unlikely you’ll ever need that short a timeout.
I think about 25 seconds is the shortest timeout I’ve ever programmed.
I normally go with…
How long does the blind take to roll Up + ~5 second
My curtains are exactly 15 seconds… if I put it to 16 the motors will detect this and actually revert back a little… 14 leaves just a little bit of curtain open…
Arrrrr
I’m guessing you don’t have an overlap bar in the middle, to account for that bounce back.
Hi RCZ,
Is it an option to play with the calibration times?
I, myself, didn’t use it and as MDAR said, most of the time it’s “more or less” 25 seconds.
The motor of my screen is programmed on 0% and 100% to stop, so a second more or less is not a problem.
And if I’m correct, you could set this calibration time to 1 second, so it rolls one second longer to make sure the blind is fully seated. Or when opening to get the blinds the first lift-off and then start counting for the 0% - 100% positions.
Not sure if it works…
