Hi, Am have just installed my first velbus system at home.
I have 2 questions which I have still not managed to sort.
I have 3 VMB1DM dimming modules. One has 4 LED GU10’s connected, two has 8 LED GU10’s connected. All at 240v. The third has 3 LED GU10’s connected. The first 2 are working fine but the third set, one of the LED’s is always on and they will not dim. I have swapped over to another dimmer and they do the same so its not a hardware fault. The first 2 sets are inceptor micro LED’s and the third set are just straight GU10’s in a standard mounting, so guess this has something to do with it. It might be I need another module for this set? (the third set are 3 x 4.5w 240V bulbs)
How do I wire in the push button connection to the vmb1dm? I have a momentary switch that is 3 way. Up down and in the middle off. Can this be used? I assumed pressing up once would turn it on, holding it down would dim and a quick press down would turn off?
Thanks in advance,
Chris.
