VMB1TS does not fit in BTLN4702 / VMBGPFS
I have a VMB1TS and a couple of VMBGPFS (which is a BTLN4702), but it does not fit.
The VMB1TS has sharp corners, but the frame has rounded corners.
I think the same problem applies to the controller VMB1TC, which also has sharp corners, so i suppose that also does not fit in al BTLN4704 frame together with a VMB1TS.
What am i doing wrong here?
Steef
I had to cut the corners, if you look closer there are 2 lines already there on the corner. Just extend them with a sharp knife.
