When you configure the VMB1TS module to switch between heating/cooling mode using a remote switch. The module shortly activates the heater/cooler output and possible linked relay outputs after mode switch. Can the VMB1TS module be configured not to activate those outputs while switching between modes? Thanks for the response?
When using the new relay modules VMB4RYLD or VMB4RYNO you can forced off the linked relay channels by the remote switch.
The heating mode remote switch must ‘forced off’ the cooler outputs and ‘canceling the forced off’ mode for the heater outputs.
The cooling mode remote switch must ‘forced off’ the heater outputs and ‘canceling the forced off’ mode for the cooler outputs.
