VMB2PBN diisable led feedback
today i installed 6 vmb2pbn modules, but i have switched without feedback, so there is no use in making the led light up when the channel is active.
Can we disable the leds?
Open the configuration dialog of the VMB2PBN module and select the LED Indication tab.
Select the pushbutton for which to disable LED feedback, and click Edit.
Select Monitoring and click OK.
The pushbutton should now be set to monitoring.
Monitoring is used to get feedback from a specific channel, but if you set it to monitoring and don’t link any channels to monitor, then you’ve disabled the feedback.
