wow thanks for the fast response. My fault, I didn’t take the time to calculate, but indeed, I forgot how big numbers you could make with a little of bytes…
So the biggest fade time is : 0xFFFF = 65535 /60 /60 = 18,204166 hours
Then you can’t make any fade time of 3 Days like explained in the PDF with mode? Or Am I still missing something?
Or the manual says : “The dim time is limited to 1 day” This wil mean 18 hours then?
Actually both are correct, COMMAND_SET_DIMVALUE (as described on page 7) only accepts a 16-bit time in seconds, which is a maximum dim delay of roughly 18 hours.
However, when working with module memory (page 11 of the protocol), you will see that actions are saved in groups of 6 bytes of which the third byte is the ID of the action you want to perform (the complete list of actions is on page 13).
Some actions have parameters, with a maximum of three parameters per action. If an action has a ‘Dim time’ parameter, then the value is formatted according to what is noted on page 14. With a value ranging from 1 second to 3 days.
You can see this in action on the VMB4RYLD and VMB4RYNO modules in VelbusLink, for example:
