Vmb4dc with fluorescent lamps
Dear,
In the manual I read :
Dimmer delay:
If the dimmer module will be used to dim neon lighting, link relay channel in a momentary control to the dimming
channel in order to switch the lamp on or off. As soon as the dimming value is not 0 (zero), the relay channel will
be activated. To allow the lamp to ignite, you must
set a dimming delay during which the lamp’s dimming process
will be briefly stalled.
The dimming delay and relay contact are not necessary when dimming neon lighting.
Switch-off delay:
The neon lighting’s dimming can be linked to a deactivation delay of the relay channel as soon as the dimming
value drops to 0%, this in order to prevent the lamp’s restart when dimming it off and on again.
This feature is not necessary when dimming neon lighting.
How do I program this in velbuslink? Or where can I found more information on this?
Kind regards
Wim
