I have a couple of VMB4RY modules now which have failed in the same way, specifically that the output of relay 4 flickers on and off several times per second (but not a regular frequency) when the relay should be set to “on”.
One of these was attached to a couple of CFLs and only on intermittently, the other was attached to a small valve (so a inductive / coil load) set to be on constantly.
- Is this a common failure mode and 2) (as they’re well out of warranty) any repair tips?
Thanks,
T
