VMB4RYLD - contact NC - feedback led
Hello Support,
Possible to set the feedback led to active when a contact is changed to NC instread of NO?
Greetings,
Bart
hi,
I don’t fully understand your question but can’t you resolve the problem by linking your feedback led to another relay (function monitoring)?
you can use relay y as inverted from relay x by linking it using 2 actions (2.OFF + 17.start timer while opening contact/continuous)
Kris Daelman
Hi Kris,
Maybe I didn’t give enough details.
My ventilation system is connected to VMB4RYLD on a contact set to NC.
So the ventilation is always working, but the physical led on the VMB4RYLD isn’t lit up, only when i switch the contact ON = ventilation off.
Which makes absolutely sense, I was just wondering if the LED function could be inverted too?
So i can see through the homeserver that the ventilation is operational.
Or should I configure this in a different way?
Greetings,
Bart
