You have a Relay 1 active at night (I don’t know how you do this!)
You have a pulse input on VMB7IN Channel 1
You have this same pulse input on VMB7IN Channel 2
Forget the third input on the 7IN coming from the relay and the electrical connection of this last module
Now, try this :
Relay 1 >> Lock channel at closed switch of VMB7IN’s Channel 1
Relay 1 >> Lock channel at opened switch of VMB7IN’s Channel 2
FYI, the relay for night use was installed by the electricity supplier.
It’s a huge 80amp contactor, which feeds a totally separate electrical distribution board.
That board previously supplied power to night storage heaters. (Which have been removed now that I have fully zoned gas central heating)
All I’ll do is pick up the 240v switched output and use it to close a small 240v relay, which will close an input on the VMB7IN.
