VMB8PB firmware version
But the command memory dump request (CB) do not produce any answer from the module VMB8PB. In the latest version 0736, I suppose the module VMB8PB will answer to the command CB.
Best regards.
Alberto
  • I’ve cleaned up this topic for simplicity in case another user browses this forum -
The memory dump command enables you to retrieve the memory a bit faster from the module (1-2 sec instead of 7-8). A small difference because the module has limited memory. Nothing functional has changed about the module.
However, if you want the latest firmware, please send your module to our headquarters. Shipping costs will be at your expense.
Velleman nv
Legen Heirweg 33
B-9890 Gavere
Belgium (Europe)
Regards
