Thanks VEL450.
If I choose “inductive” then none of my LEDs work at all – I get blinking-panel-led errors from almost all the dimmers.
Inductive mode is only suitable for old iron-core transformers. I have 106 VMBDMI-R on this project, all are happier on “resistive”. I am very aware because they all default to inductive… this caught me out initially, I thought they were faulty. I had to configure them all “resistive” manually. Your own configuration settings emphasize that “Resistive mode – Dimmer suitable for… dimmable LED lights and some electronic transformers…”. Almost nobody uses iron-core transformers any more. These devices really should default to resistive. Inductive setting will result in LED-flicker or errors.
I have a mix of Aurora MPRO (1A and 2A) downlights; from 1 to 8 per dimmer. With also some separate chandeliers with SES LED lamps, and some wall lights with SES or ES LED lamps.
All lamps are major brands (OSRAM, PHILIPS, TALA) dimmable LED filament.
And for LED strip-lighting I have some constant current and constant voltage dimmable LED drivers all carefully chosen.
I have been testing and using the Aurora downlights since 2019 and all revisions since (E8, MPRO 1, MPRO1A, MPRO2 MPRO2A) have worked very well.
For the most part they all great. Really smooth dimming, no flicker at all anywhere. None of the problems I see with most push-dimmers, even L+N powered ones.
Main variable is the dim level at which they come on. The LED drivers I use come on at around 15%. The downlights at about 40%. The SES bulbs at about 50%.
So to be able to configure minimum dim value is great and it normally works very well… but not in master+slave configuration… there you clearly have a firmware bug.
I am aware of the VMB4DC+Finder recommendation… it was made shortly after I purchased 70+ VMBDMI. Too late for me to change. I was not amused.
And I must say… the VMBDMI-R are working fine. I do have just a few VMB4DC and FIN15.11.8.230.0400… they do not work any better for my LEDS (though they are slightly more compact at 6 vs 8 DIN rail units for 4 dimmers) and most importantly they are a pain to wire-up bus connections in volume because they cannot use VMBRAIL… too many flying wires (think about wiring for 100+ dimmers).
I have been using Velbus since 2010. I use VMB4DC to control my ventilation fans. I use VMBDMI-R to control my towel rails. I have 30+ home-made wall switches using VMB8PBU (these are really nice, I should post photos here).
I was an original investor in many VMBDME… (your previous trailing-edge dimming solution for electronic loads like LED) which did not go well.
Those were replaced with VMBDMI.
And then those were all replaced with VMBDMI-R.
And now you have no in-house trailing-edge solution at all
Please do not get me wrong… I love Velbus. I want more Velbus. There is a lot that is great about it. But we need a new dimmer product.
I would love to see a properly configurable reliable 4-channel 230V AC dimmer, configurable for leading or trailing edge, in a 72mm span. I would use those in new projects. And if you have anything in development I would be happy to test it.
Andy
