VMBGP panels do not fit well in VMBGPFS
Several of my VMBGP touch panels do not fit well in the VMBGPFS support.
It happens that only 1 or 2 corners clip properly.
Is it something that others have also experienced? How to improve this?
Thank you
Christophe
It is a very tight fit.
Can you check that the VMBGPFS are perfectly flat?
Any warp will cause the panel(s) to pop out.
Releasing / unscrewing the frame a little can allow them to find a level. (You can always pack out the gap if needed later)
In extreme cases, it could just be that the holes for the glass panel tangs need opening up just a tiny bit.
Put a flat blade screwdriver in there and give it the tiniest twist.
Just to release them enough so that the barb on the tang gets a little deeper in and can be held in place.
Thank you for your reply.
Indeed, I noticed that the VMBGPFS are not perflectly flat… I’ll try to correct that first before trying to enlarge the holes in the frame.
Thanks!
Christophe
In the not-working frame, there were 2 holes in which the OLED did not fit (even unmounted from the wall), although visually they looked fine.
I changed the frame with a new one and now it works.
Thanks for your reply.
Christophe
