I’ve changed the parameters (from all my VMBPIRO devices) to the following partakers:
Temperature: Send when changed
Light Value: Send when changed
Now when I look to the output in the log file then I see still a lot of changes for the 0x0F
Just a wild guess, but could it be that the resolution for the temperature reading is too sensitive? Since looking what I have receive this is only temperature data from the 0x0F modules.
Do you want me to make the changes to only transmit x seconds?
admin@nasstation:/volume1/@appdata/homeassistant$ tail -f homeassistant.log | grep SensorTemperatureMessage
2021-12-07 14:58:23 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 14:58:38 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 14:58:54 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.375, “min”: 127.4375, “max”: 9.0}
2021-12-07 14:59:10 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 14:59:25 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.375, “min”: 127.4375, “max”: 9.0}
2021-12-07 14:59:41 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 14:59:57 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:00:12 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:00:28 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:00:44 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:00:59 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:01:15 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:01:31 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:01:46 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.25, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:02:02 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.25, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:02:18 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.25, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:02:33 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.25, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:02:49 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.25, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:03:05 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.25, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:03:20 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.25, “min”: 127.4375, “max”: 9.0}
2021-12-07 15:03:36 INFO (velbus-process-reader) [velbus] New message: {“name”: “SensorTemperatureMessage”, “priority”: 251, “address”: 15, “rtr”: false, “cur”: 4.3125, “min”: 127.4375, “max”: 9.0}
