Who is writing his own soft in C#?
Is there anyone that can write a serverprogram in c# to communicate with velbuslink?
Stis
Stis
Mine is in “C” but is programmed to work unther linux. You can recompile it as you want with mingw or equal to use it unther windows.
I did it
And it is able to addressed by Silverlight or others
What do you want exactly ?
Actually, what I did is to adapt the SDK provided by Velleman to allow access to my server.
I did it months ago… I think I designed it to let it connect to VelbusLink aswell…
I check and come back…
The Velbus Library for .NET can be found here:
velleman.be/downloads/files/ … buslib.zip
It contains the basics of Velbus I/O using the built-in .NET 2.0 SerialPort component. Theoretically it could be expanded by creating a new component that implements the Velleman.Velbus.IBusInterface interface and uses sockets instead of the serial port.
You can also download VelbusLink 6 which has a built-in server. Don’t try to configure your modules with VelbusLink 6 though…
