Because the VMB1RYS only has one input and zero virtual buttons, you’d have to use some third party logic software to keep tabs on relay / light states and use the button presses as triggers…
Or try to create the logic with multiple virtual relays in other modules
I don’t want to take it out of the wall now, but I need to check if I have another VMB6PB-20. I could put together the module and the switch and show how they fit in the single wall box “on the table”.
A few more VMB6PB-20, VMB1RYS, glass switches, roller shutter controllers installed. All works as expected. The “new” DIN rail mounted units to connect velbus cables are fantastic I’m planning to do a bathroom next - the floor heating will be the most interesting part. I think I’ll use the vendor provided thermostat, but with additional temperature sensor(s) and an power override option controlled by velbus.
I think I don’t need a fancy floor temp. regulation, so a Velbus relay VMB1RYS + temp. regulator like the one below + 3 temp. probes (the main one, the velbus one and a spare to avoid future problems) should cover the regulation, emergency shut off and energy saving settings.
