Yes I can confirm, just tested this code:
"id": "dff627b9.b51c08",
"type": "velbus-send-raw-bytes",
"z": "e143c9bc.3a1eb8",
"name": "Send Raw Bytes",
"connector": "2a1a837f.ef12bc",
"dataBytes": "",
"dataBytesType": "PAYLOAD",
"address": 0,
"addressType": "MSG",
"priority": "251",
"rtr": 0,
"x": 840,
"y": 640,
"wires": []
"id": "c77b684.d3bb598",
"type": "trigger",
"op1": "1",
"op2": "0",
"op1type": "str",
"op2type": "str",
"duration": "-1",
"extend": false,
"units": "s",
"reset": "",
"bytopic": "all",
"name": "",
"x": 140,
"y": 640,
"wires": [
"id": "f1666b2.98f5f98",
"type": "random",
"name": "random 2-30",
"low": "2",
"high": "30",
"inte": "true",
"property": "random",
"x": 450,
"y": 640,
"wires": [
"40f9a309.bbf99c"
"id": "40f9a309.bbf99c",
"type": "function",
"name": "format 0xD4 for 0x81",
"func": "msg.random += 0x60;\nmsg.payload = \"0xD4 0x01 0x0F 0x\" + msg.random.toString(16);\nmsg.address = \"0x81\";\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 640,
"y": 640,
"wires": [
"dff627b9.b51c08",
"df67f7bd.267778"
"id": "df67f7bd.267778",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"x": 830,
"y": 600,
"wires": []
"id": "3b4ad771.20c788",
"type": "inject",
"name": "",
"topic": "",
"payload": "",
"payloadType": "str",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 350,
"y": 600,
"wires": [
"f1666b2.98f5f98"
"id": "2a1a837f.ef12bc",
"type": "velbus-connector",
"z": "",
"ip": "192.168.1.xxx",
"port": "yyyy"
Can you import this nodes and check?
Change velbus-connector ip/port and your edge address (mine 0x81) in function node code.
