There is a topic, but it’s ancient (1), so I feel it’s better to as again: what modules can be switched by a transistor? I got this proximity sensor (2). It has PNP output, works with voltage 10 to 30V. I know I can make it work with VMB4AN, but it feels a bit of a waste to use analogue channel for a digital input. If VMB1RYS works with a transistor input - that would be perfect. VMB7IN would be great as well, but I’d appreciate info about all modules with inputs.
P.S. I assume that the internals of VMB6IN were potentially different than VMB7IN, so the ancient info might not be valid for VMB7IN
(1) Can a VMB8PB be switched by a transistor?
(2) https://docs.rs-online.com/3eb0/A700000009787352.pdf
