What I have found so far: Underfloor heating temp sensors
Now is the 10 Ohm NTC in the floor still the best solution. I’ll probably put 3 of them just in case…
Or it’s better to put 10k Ohm? I’ll be most likely using the thermostat provided with the heating element to control it, but i want to have an independent reading from velbus to be able to shut the heating circuit down
Other reference threads, but older:
Anyone experience with using a temperature sensor in the floor the monitor the heating/cooling and prevent condensation ?
The sensor connected to the VMB7IN would monitor the floor temperature and adjust the target temperature of the room to the floor temperature.
The floor temperature should never be 5 DegC lower than the room temperature.
Thankx for all info
Hi all,
I’m looking to go full Velbus both for lighting and heating control in an upcoming renovation.
We will be installing underfloor heating and instead of also using the air temp sensor/thermostat in the glass panels, many underfloor heating system measure the slab temperature via a 10k ohm floor probe, which I would like to do to get better efficiency by having more control over the system - knowing both air temp and floor temp.
What is the best way to integrate such a temperature probe …
MDAR
November 6, 2026, 7:49am
2
Standards seem to be
10K ohm
2Kohm
If you’re thinking of linking them to a Velbus input device.
2K ohm work directly with VMB4AN
For 10k ohm, you’ll need a tiny circuit to convert 10K values to pulses.
Then you can connect it to VMB8IN-20, VMB7IN or VMB4AN
I’m not sure how a 2 ohm sensor would work with a VMB4AN, but as it’s less than 2K, you should be able to map it.
