I’ve been working on some widgets for use primarily with the Velbus hardware, but there’s no reason why they couldn’t be used with other hardware. Many thanks to @tomvancutsem for his amazing efforts, all I’ve done is tweak this to make it easier to deploy.
I’ve created two versions of the Widget, one that uses the default names that are created in PaperUI when Items are added to Things, and one that requires Items to be names according to the Widget requirements.
My thoughts are that either will work, but just depend on how people want to work.
Current Temperature = Lounge_CurrentTemperature Watch out for this one, as default would be Lounge_Input_Lounge
Current Target Temperature = Lounge_Thermostat_CurrentTemperatureSetpoint
Operating Mode = Lounge_Thermostat_OperatingMode
Current Mode = Lounge_Thermostat_Mode
Heating Mode Antifrost target = Lounge_Thermostat_HeatingModeAntifrostTemperatureSetpoint
Heating Mode Night target = Lounge_Thermostat_HeatingModeNightTemperatureSetpoint
Heating Mode Day target = Lounge_Thermostat_HeatingModeDayTemperatureSetpoint
Heating Mode Comfort target = Lounge_Thermostat_HeatingModeComfortTemperatureSetpoint
Cooling Mode Antifreeze target = Lounge_Thermostat_CoolingModeSafeTemperatureSetpoint
Cooling Mode Night target = Lounge_Thermostat_CoolingModeNightTemperatureSetpoint
Cooling Mode Day target = Lounge_Thermostat_CoolingModeDayTemperatureSetpoint
Cooling Mode Comfort target = Lounge_Thermostat_CoolingModeComfortTemperatureSetpoint
I’ve also been working on tweaking an alarm clock widget, so that it works well with the Velbus alarms, please take a look at this forum post on the openHAB community site
Hi MDAR,
checking in to investigate progress on VBM1TS integration. Possibly more a github question, but I spotted some updates in the source files
“Added support for the VMB1TS (#4)”
It is possible to generate a new JAR file for testing purpose? Can you explain me how to locally compile?
In the ideal world alternatively using your script to facilitate updating the velbus binding, but I believe this refers to the official release from 2019 Feb 3rd.
(if not stable or released, happy to take the risk for testing purpose)
General question: Also OpenHab is going for 2.5 release, I assume/hope the velbus binding is still compatible in 2.x releases?
Thanks a lot for the clear instructions. I think the script/update was successful as I’m able to manually add the VMB1TS, unfortunately something is wrong at my setup, since after the works the blinds and meteo are not responding anymore / though relais/input modules are still reacting. I initially assumed a bus error but the windows velbuslink is still able to discover them all. The output of Karaf console can be found below (it looks indeed i’m running 2x the velbus binding). What the best troubleshooting action now? (remove the velbus binding from PaperUI and start again?)
I suspected that might happen, which is why I said you check that you only have 1 bundle loaded.
The 2.4 version should vanish if you reboot, or you can remove it from the database (because the JAR file was deleted by the script) by simply starting the Karaf console and entering (in your specific case, other people will have a different number)
bundle:uninstall 219
“2.5.0.201908142035” is the development version, there are a few bugs in it, which I’m sure Cédric will address when he has time.
You may need to disable and re-enable the Velbus Network Bridge (or serial) bridge to force and update of all of your Velbus modules within openHAB2.
I find it easiest to do this in PaperUI, by clicking on the clock symbol (again after a pause of a few seconds)
Hi,
Almost there … all modules working again after removing v2.4 and VMB1TS is now auto discovering/recognized in “inbox”, but for some reason not “online” yet (despite reboots, disabling serial bridge, reinstalling serial bridge)… sorry but still some hints required? Any minimum prerequirements with respect to firmware level ?
Thanks a lot
Dear MDAR & Cedric,
Thank you very much for the successful development of the integration of the 1TS module
Initial tests are looking great, working like a charm.
Note to all: I purchased the velbus system back in 2009 (yes 11 years ago). Interesting to see all modules are still backwards compatible and even new developments are made for this older module.
That’s what I call a perfect service and I never regret my good decision to select Velbus.
I hope this convinces new buyers as well !
Hi,
My vmb1ts thermostats are working in openhab, but since the update it looks I a have problems with the connection with velbuslink and openahab at the same time, I’m loosing modules or it takes very long time to detect them in velbuslink and in openhab. Is somebody have the same?
I don’t think this is related with the upgrade. If you are using Velserv to be able to use both VelbusLink and OpenHab, I think this is the issue (also others have similar issues). I’m using the direct (serial/COM) connection as I also experience desync status updates. (of course with limitation that I only use OpenHab)
@MDAR, I was trying to get your temperature widgets working, the original one VelbusThermostat.widget.json works partly (actual temperature doesn’t show), the updated version I can’t get to work out of the box (VelbusThermostatStreamlined.widget.json)
Do you have it working with you with the 1TS module?
The problem appeared since the vmb1ts are recognized.
Before it was working perfect with velserv, openhab and nodered on the same pi.
I tried a fresh setup this evening and everything worked till…I updated the binding…
You should be able to get the widget working, it’s normally not much more than an Item name issue.
Can you double check with the text file in the zip ?
I suspect your Current Temperature Item has either the wrong name, or it’s a Number:Temperature, rather than a basic Number.
(FYI, don’t forget that you can link multiple Items to a Thing channel, if you want to try different spellings etc)
Hi,
Sorry for the screenshots, but I don’t see the “knopinstellingen”
Also not 100% sure i’m using the latest VelbusThermostatStreamlined.widget.json (note, I also didn’t “load” the Widget_Ani.gif). I’m pretty sure i’m doing something wrong but I don’t see immediately what is incorrect. Currently I only see the background / ref right block in first screenshot
the original module is functioning fine except current temperature is not showing based on default item names.
Any ideas based on below screenshots? (note testing both versions)
There is also a folder of Screen grabs to show the construction of the Items in PaperUI.
Widget_Ani.gif is / was just an animation of the older screen grabs and is nothing to do with the Widget.
It might be quicker to directly edit the widget directly within HabPanel (“Manage widgets”), rather than try to remove them and import these new versions.
The advantage of editing the widget is two fold…
You’ll see how they are constructed
Your edits will be reflected directly into any used copies of the widget and work straight away.
For reference, here are snippets of code from each widget so you can see how the Item names are used and see the changes I’ve made.
Still happy with my items file to manage the +500 variables (a bit challenging with the PAPER UI)
as example …
Number Bureau_CurrentTemperature {channel=“velbus:vmb1ts:003e088b:99:input#CH1”}
Number Bureau_CurrentTargetTemperature {channel=“velbus:vmb1ts:003e088b:99:thermostat#CURRENTTEMPERATURESETPOINT”}
Number Bureau_HeatingComfortTarget {channel=“velbus:vmb1ts:003e088b:99:thermostat#HEATINGMODECOMFORTTEMPERATURESETPOINT”}
Number Bureau_HeatingDayTarget {channel=“velbus:vmb1ts:003e088b:99:thermostat#HEATINGMODEDAYTEMPERATURESETPOINT”}
Number Bureau_HeatingNightTarget {channel=“velbus:vmb1ts:003e088b:99:thermostat#HEATINGMODENIGHTTEMPERATURESETPOINT”}
Number Bureau_HeatingAntifrostTarget {channel=“velbus:vmb1ts:003e088b:99:thermostat#HEATINGMODEANTIFROSTTEMPERATURESETPOINT”}
Number Bureau_CoolingComfortTarget {channel=“velbus:vmb1ts:003e088b:99:thermostat#COOLINGMODECOMFORTTEMPERATURESETPOINT”}
Number Bureau_CoolingDayTarget {channel=“velbus:vmb1ts:003e088b:99:thermostat#COOLINGMODEDAYTEMPERATURESETPOINT”}
Number Bureau_CoolingNightTarget {channel=“velbus:vmb1ts:003e088b:99:thermostat#COOLINGMODENIGHTTEMPERATURESETPOINT”}
Number Bureau_CoolingSafeTarget {channel=“velbus:vmb1ts:003e088b:99:thermostat#COOLINGMODESAFETEMPERATURESETPOINT”}
