can i use VMB1DM to dimm LED lamps?
what do i need to have for that?
No, the VMB1DM cannot dim LEDs at this time
We do not have a dimmer in our range for such purpose
Future developments may include LED control and dimming, if there is a commercial interest.
Are VMBDME compatible with dimmable led lamps?
Are they using same technology than VMB1DM?
VMBDME are not compatible for dimming LED lamps.
Also VMB1DM as well as VMBDMI-R are only for resistive and inductive loads, not for LED.
We have the following alternative to dim LED lamps.
0-10V Velbus module together with compatible LED dimmer from Finder.
- VMB4DC ==> 4-channel 0/1-10v universal dimmer controller
- FIN15.11.8.230.0400 ==> Slave dimmer 0-10 v input - 230 vac - 400 w
To dim LED strips you can use the 2 channel 0-10V PWM dimmer together with 4ch 0/1-10 universal dimmre controller.
Best Regards,
Velbus Team
Thanks, I’ll give it a try… ![]()
