Bridging Velbus with TCP through snap package
Hello everyone
We’ve made a snap package to easily run a Velbus TCP gateway on any snapd-compatible Linux distribution.
To install, simply run these two commands;
snap install velbus-tcp
snap connect velbus-tcp:raw-usb :raw-usb
The server will now listen at 27015 (which you can connect to with VelbusLink).
Source code and further information can be found at https://github.com/velbus/velbus-tcp-snap
Hi
Do you have a systemd service file to automate the starting and stopping of this service in Linux?
Hi MDAR,
This snap starts automatically. It does not require a systemd service file.
To start the snap:
snap start velbus-tcp
To stop the snap:
snap stop velbus-tcp
Thanks :slight_smile:
I meant to start the service at boot up :wink:
Hi MDAR,
It starts automatically at boot up. :smile:
You can check the status of the snap with
snap services velbus-tcp
It should say
Startup: enabled
Current: active
Hi
I’ve got some bad news :frowning:
I tried to install this Snap on a fresh Ubuntu 18 device and it failed :frowning:
The commands I ran were
apt-get install snaps
Snap installed correctly, but velbus-tcp failed.
The second snap command
Reported that there wasn’t a raw-usb plugin available
There were a number of lines of text displayed during the installation of velbus-tcp but they were on the same line so couldn’t be captured.
Extra info
root@odroid:~# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.3 LTS
Release:        18.04
Codename:       bionic
 root@odroid:~# ls /dev/serial/*
  dev/serial/by-id:
Velleman_Projects_VMB1USB_Velbus_USB_interface-if00
/dev/serial/by-path:
platform-dwc2_b-usb-0:1.2:1.0
Hi MDAR
To get the full output snap log, you can use ‘snap changes’ together with 'snap tasks ’ e.g.
It seems the snap can’t be installed due to a seccomp error.
Looks like a snapd error, following a similar thread on the official snapcraft forum I found it might be kernel related:
Try to create a new thread over on their forum.
Also, you should not have to install snapd on a fresh Ubuntu 18, so might also have something to do with that.
Kind regards
And how do you connect if all is ok, from Velbuslink ? Chosing Network connection adding the IP and the port, or Signum/USBIP choice ?
You should select ‘Network’, filling in the IP/port.
